11-04-2017 11:01 AM - last edited on 08-27-2024 10:38 AM by Danny
I'm going to get straight to the point.
My Canon MX700 series printer has a stuck ink cartridge. The cartridge is black ink and I've been trying to use my hands and a tweezer to get it out, both aren't working. The tab also won't work and get it out. Any other suggestions or am I beat?
Thanks,
Fred
11-04-2017 11:10 AM
Hi, Fred!
Thanks for posting on our forum! This community is designed for your fellow Canon owners to help each other out with any problems they may encounter. If this is a time-sensitive matter, search our knowledge base or contact our US-based technical support team at http://canon.us/SupportCF
Thanks and have a great day!
11-22-2017 04:10 PM
Hi Fred,
It may be easier to remove the black ink cartridge if you remove the other inks first. Also, if the tab is not releasing the cartridge, the ink may not be seated quite straight. Make sure the ink tank is square in the print head, then push on the top of the cartridge until you hear a click. You should then be able to remove the cartridge.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
08-26-2024 02:10 AM
Same problem here. How do i remove thi?
08-26-2024 08:24 AM
Hello there!
Thank you for reaching out!
Please note that the MX700 was retired in 2014, and as a result, all official Canon support has ceased.
To explore Canon's latest technologies, we recommend contacting our Canon Upgrade Program Specialists at 1-866-443-8002, available Monday through Friday.
We hope you have a great day!
08-26-2024 08:29 AM
Mine is canon mg3070s
08-27-2024 10:40 AM
Thanks for letting us know that! Since you've got an altogether different printer model, we recommend that you start a new thread for this issue.
