HELP! My Pixma mx490 keeps wanting to print in fax mode
igecko21
Ok, so I have a Canon Pixma MX490; it keeps wanting to print as fax for some reason and this is the first time this has happened, So I uninstalled software and reinstalled but the issue still occurs... can anyone help me with this situation ? I am getting no errors....
5 REPLIES 5
BillS
Mentor
Hi igecko21,
In order to better assist you, please allow me to ask a couple questions:
  • Which version of Windows or Macintosh are you using?
  • Are you connecting wirelessly or with USB?
I look forward to your reply.
Windows 7 (PC) and its connected via USB.
Hi igecko21,
Please make sure that your PIXMA MX490 is set as the default printer.  To do this, please follow these steps:
 1.  Click on Start and then Control Panel.
 2.  Click on Devices and Printers.
 3.  Right click the PIXMA MX490 series Printer and left click on "Set as default printer".
Once set, there will be a green check mark on the printer.
Please attempt to print.
If you continue to have difficulties, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
I have windows 10 and my printer is connected via WIFI
Did you every figure out how to fix this? I am having the same problem.
