08-17-2022 10:12 PM
I looked through the manual trying to figure out how to check for updates for the IJ Utility and my G7000 printer. After a lot of searching all I found was how to check or get firmware updates IF my G7000 is connected to the internet via a LAN or Wi-Fi connection. I don't use either. My G7000 is connected via USB to my Windows 10.
Also, the only Canon software on my PC is the IJ Scan utility and the IJ Printer Assistant Tool. Seems like I should be able to check other things from my PC like G7000 firmware and software updates.
How do I check for firmware and software updates, then download them if they are out of date ?
David
08-19-2022 01:59 PM
Hi David121,
Any updates to software or firmware that are available for download will be available using this link:
https://www.usa.canon.com/support/p/pixma-g7020
08-07-2024 04:27 PM
Hi @Patrick - is there any document for the new firmware? I found my G7020 (US) recently indicated a new FW was available, but no documentation seems to exist for this (including on the above link, where there is no information at all about Firmware, only drivers/software). Is there perhaps some internal document that can be published for this?
