07-31-2021 10:03 PM
Router / local network is capable of IPv6 protocol but ISP doesn't provide IPv6 address
Printer is able to check for new firmware (it alerts you that new version is on server)
But is unable to update until IPv6 is disabled
BTW where can I find the update/firmware history?
Cheers.
09-22-2021 04:18 PM
Hi loyukfai,
To disable IPv6 on your printer, please follow these steps:
1. Please press the wrench and screwdriver button 1 time
2. Use the right arrow to select Device Settings and press OK
3. Use the right arrow to select LAN settings and press OK
4. Select Wi-Fi and press OK
5. Use the right arrow to select Manual setup and press OK
6. Use the right arrow to select TCP/IP settings and press OK
7. Use the right arrow to select IPv6 and press OK
8. Press OK on the displayed message
9. Press OK on Enable/disable IPv6
10. Use the right arrow to select Disable and press OK
09-23-2021 11:24 PM
Thanks! Sorry forgot to mention that I figured it out already. However I believe it should be something to be fixed in future firmware?
Cheers.
