11-04-2014 06:24 AM
11-06-2014 05:16 PM
11-06-2014 07:22 PM
11-06-2014 07:26 PM
11-06-2014 07:29 PM
Hello MikeCBX!
Canon does not provide direct support for imageRUNNER series products, but your dealer will be able to help you! If you don't have a dealer, please call us at 1-800-OK-CANON (1-800-652-2666), and we will be happy to provide you with the names of dealers who are in your area!
11-06-2014 07:32 PM
11-07-2014 06:35 AM
11-05-2015 05:04 AM
we are experiencing a very similar if not same problem here.
our printers will cause office apps to freeze and often close when attempting to print.
has anyone had any update on this as to whether there is patch etc to resolve?
regards,
Webb1_1
11-05-2015 08:48 AM
I found the problem last year when I posted this. The issue is 100% with the driver version of the Fiery. We had our Canon rep and printer managed Service Provider push Fiery and they did indeed publish a driver that fixed the problem.
Our problem with was with IR-ADV C5255,6275, and 7200 series.
The driver that was failing if you check the logs for us was:
C:\Windows\system32\spool\DRIVERS\x64\3\EF066828.dll
C:\Windows\system32\spool\DRIVERS\x64\3\EF909315.dll
C:\Windows\system32\spool\DRIVERS\x64\3\EF380954.dll
And all this was associated with the A2,B2, and C2 Fiery. Another thing to note - PCL drivers are apparently not affected, just PS. It has something to do with the timestamping in the driver and not being able to figure out the change.
Fast forward a year later I am now in a new environment with Xerox Printers and Fierys and it happened to us this past week and the UK the Week before. Root cause is Fiery - I'll try and dig up the driver info that was sent to us.
Where are you located? I may be able to put you in touch with some of the guys that I worked with to solve this
11-05-2015 09:30 AM
thanks for getting back so promptly. Anything you manage to pull up on the drivers would be great.
We are running Canon imagerunner C5255's with an E1 fiery. Ever since the daylight saving switch over we have had users freezing when trying to connect to the printers and in many cases unable to connect completely. Oddly though it doesnt effect all users.
we are in Holborn, London. We have a service manager so I will pass this on to them.
Any info you find would be much appreciated.
Thanks again,
Danny,
