'Failed to change settings' message on Android, when attempting to print from Canon Print Service.
Harrisphoto77
Most likely, you'll be able to 'share' the data to the Canon Print inkjet/Selphy App.
Another possible workaround...
On the android device.
Go to Settings->Application manager
· Touch More button and select “Show system apps”
· Open Android System WebView
· Touch Disable button (and touch Disable or OK or Agree in each popup)
· Touch Enable button.
Also, auto update of Android System WebView should be disabled (it can be done in Play Store app).
2 REPLIES 2
Tiffany
Moderator
Moderator
Hi Harrisphoto77,
Welcome to the Canon Forum!
So that the Community can help you better, we will need to know what  model printer you are using.  Any other details you'd like to give will only help the Community better understand your issue!
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team by phone or email.
Thank you!
tweetyden
your instructions did not work. I do not understand what is happening as I have always been able to print from my phone. I have a Samsung S20 plus. My printer is the Canon MX920
