06-16-2026
10:11 AM
11:07 AM
Big help needed. Using IX6820, bought it used, arrived looking brand new other than it was missing its print head. Bought a new print head and ink cartridges, installed the new drivers as of 6/15 to a windows 11 laptop. Wired directly to the laptop via USB with wifi disabled. Here's what's going on:
I have had successful prints when printing via the canon print app plugged directly into an ipad. I just cannot assign the right print settings from that app and need the more in-depth print settings that come with a laptop/desktop interface.
Help appreciated in advance 😄
06-16-2026 11:05 AM
It could be that the connection going on and off is related to the printing issue. It could be a faulty USB cable or the port it is connected to, which often is caused by a hub, not connected directly into the printer. A clogged printhead can also cause printing problems but not a USB goin on and off, and since you have a new print head that should not be causing the issue. Have you printed a nozzle check? It can be done from the printer itself which will bypass your USB connection. If it does not complete the print then something is wrong with the printer itself. Load a sheet of A4 paper and do the following.
Wait for Completion
Do not perform any other operations until the printer has finished printing the nozzle check pattern.
