05-23-2017 07:28 PM
Hello all, when I use duplex (two-sided) printing (set to high quality) on my Pixma MG7520 printer, I find my images printed are of a very low resolution. I realize this might be intentional, and that the printer might be trying to save ink as to not bleed through to the other side, however are there any settings I can change to prevent this? Should I use a different driver? Any thoughts? Thank you very much!
- John
05-26-2021 05:27 PM
If you only use black ink you can try by print options in the tab maintance to change ink cardridge-options to only black. Maybe a little late but i just figure this out 😛
05-24-2017 04:26 AM
Hi johncpatterson,
Click HERE for detail steps to perform to acheive the best quality duplex prints possible from the PIXMA MG7520.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
05-27-2017 08:38 PM
Thank you for your reply, however the instructions that you linked to do not refer to any settings that affect quality and/or images. Does anyone else have any ideas by chance?
Thanks!
- John
05-26-2021 05:27 PM
05-26-2021 05:37 PM
