08-31-2025 04:57 PM
Hello,
I recently bought a TS7700 all in one printer. I am contemplating moving from Windows 10 Pro to Windows 11 Pro and wanted to be sure my printer will continue to work. Do I need different software or drivers for Windows 11?
Thanks!
09-02-2025 11:22 AM
Yes. The TS7720 is supported under Windows 11. Downloads are available here.
PIXMA TS7720 Wireless Home All-in-One Printer https://share.google/NeYqVsipvyPszpe1e
09-02-2025 09:53 AM
Thanks for joining the conversation, HLily!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA TS7700 series. The model number should appear on the front of the printer at the lower right corner. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
09-02-2025 10:11 AM
Thanks so much for the reply. It is the TS7720. I just got it a few months ago and wanted to be sure it would work with Windows 11 if I do upgrade my laptops. And also, if any different software or drivers would be needed for the different OS. I currently have Win 10 22H2 and the printer/scanner works great on that.
Thanks for an help you can offer!
09-02-2025 11:22 AM
09-02-2025 12:50 PM
Thanks! Great news!!
So the drivers and software I downloaded when I first set up the new printer with Win 10 will work if I upgrade the laptop to Win 11?
09-08-2025 08:14 AM
In some instances, peripheral devices have to be reinstalled after an operating system upgrade. If it doesn't work after the upgrade, uninstall it restart and reinstall using the drivers for Windows 11.
09-08-2025 08:58 AM
Thanks so much for the update. Hopefully it will all work, but good to know what to do if it doesn't!!
LH
