Department ID Authentication Keeps Showing Up With IR-ADV C5540
BaseL0
Hello
We're trying to monitor the amount of prints/copies per user so we've enabled the Department ID feature and we've assigned each user one Department ID. From Printer Properties > Device settings we shall find Department ID/PIN settings
In this window we can add Department ID / PIN for each user, while the "Confirm Department ID/PIN When Printing" is unchecked, it keeps asking to enter the Dept. ID/PIN after each print. Is there a solution ?
Thanks
2 REPLIES 2
BaseL0
Other common issue is that after printing this window will pop:
after pressing ok the Dept. ID/PIN window will show, pressing ok there will make the print.
Stephen
Moderator
Moderator
Hello, BaseL0!
Thanks for posting!
While our Forum Community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products, but your dealer will be able to help you!
If you don't have a dealer, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers who are in your area!
Friends and Family
