Delete MP Drivers, then reinstall MP Drivers
paolo99
Hello I have a Canon TS6050 printer and have got this message when I try and use the scanner
"Scanner reported an error - A required file is missing or corrupted, or settings are incorrect. Try the installation again."
I've read online that I need to Delete MP Drivers, then reinstall MP Drivers. I have a Mac with the latest OS Catalina and I can't find anywhere to delete or uninstall the drivers.
3 REPLIES 3
You printer is supported under OS Catalina, but I don't think there is an MP driver available.
Have you recently upgraded from a previous MAC OS?
https://www.canon-europe.com/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_t...
I see a CUPs driver for printing and an ICA driver for scanning.
I would suggest downloading each.  Then uninstall the printer and all of its software from your MAC.
Apple menu, System Preferences > Printers and Scanners...  then right or ctrl+click from the printer dialog and select Reset Printing System.
Note: if you have more than one printer installed, it will remove all of them.
Now user Finder > Applications folder and drag everything Canon into the trash.  Restart and run the new installers... CUPS first, then ICA.
Big Thank you Rick from the Bay Area.
I followed your instructions and it's all worked out and back to happily scanning again.
TRC2
I have this same problem- A Canon TS5060 recently upgraded Mac to Mojave Then after a few months the scanner is not working - The message
Have checked the utility, and TS5000 series is selcted but don't know how to get a required file, or reinstall, as a tech installed for me.
Friends and Family
