Code 5100 on MP560: with new print head, the carriage slams to the left and makes a grinding sound.
Ecoimp
Cheers,
I have a Canon MP560 printer. Original problem was a B200 code. Have tried Solutions 1-4 multiple times to no effect.
Solution 5: The new print head is not working. When I only put in the new print head, everything sounds fine, it goes through the spooling up, and I receive a U043 code. The issue starts when I open the cover to set in the new Canon P220 and 221 ink cartridges.
The print cartridge slams to the left and makes a grinding noise. The displays shows 5100 code and the amber light blinks twice. I have turned off the power, I have followed the advice to reset printer ink absorber, I have cleaned the clear thin strip, and I have checked for orange protective strips and foreign objects.
What now?
Cheers,
Carol
Solutions 1-5 that I have tried.
Solution 1:
  • Disconnect the power cable from the printer.
  • Wait 1 hour.
  • Connect the power cable
Solution 2:
  • Check and Clean Head contact pin condition of the carriage unit
  • Check Cable connection especially the carriage FFC
Solution 3:
  • Turn off the power
  • Open the panel
  • Turn on the power
  • Wait for print carriage to start moving to the left.
  • Let it go past half way
  • Before print carriage reaches left hand side shut the cover.
  • Leave the Printer turned on
Solution 4:
  • Unplug the power cable.
  • Open the printer
  • Push the whole print head mechanic to the center
  • While the printer still open, plug the power and turn it ON.
  • When the printhead still moving and is going to the very LEFT, close the cover.
  • Wait until its boot up.
Solution 4a:
  • Take out all of the ink cartridges
  • Lift up the grey bar by where the ink goes
  • Left the print head in the middle of the printer all while the printer was off.
Solution 4b (thank you Jeremy😞
  • Clean the plastic head primers/cleaners themselves on the printer (the far right)
Solution 4c (thank you Rhiann😞
  • Turn off the printer
  • Open the cover
  • Turn on the printer
  • Wait for print carriage to start moving to the left and let it go past half way
  • Before print carriage reaches left hand side (but after going halfway across) shut the cover.
  • Leave the Printer turned on.
 Solution 5:
  • Replace the printhead
1 REPLY 1
Patrick
Hi Ecoimp,
It would appear as though you have tried many solutions to resolve this error.  At this point, it is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
