03-16-2015
01:07 PM
01:02 PM
SamanthaW
I have a PIXMA MG5520 printer. The printer works, the copier works, but when I try to scan, I get a Code 5,157,69. I have uninstalled and reinstalled the software, but nothing seems to work. So my guess is that there is a setting which somehow got changed. Please help.
09-10-2015 01:07 PM
Hello.
Additional troubleshooting will have to be done to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
02-15-2016 10:46 AM
I have recently switched my MG7550 printer/scanner from a LAN connection to a USB connection directly into my PC. Now I can't scan using Canon sofware even though I can print. I get this error code. Grateful for any suggestions.
03-27-2016 06:00 PM
I have the same problems using Windows 10. Can't scan. The trick with paint did not work. Please help.
03-28-2016 05:29 PM - edited 03-28-2016 05:40 PM
I got the same message, same scanner issue over Wifi with an MG5550.
I eventually solved the issue and got the scanner working over Wifi by installing all the software from scratch WITH the XPS optionnal driver. The XPS driver works for me for the scanner and not the standard one.
Best regards.
Stephane.
04-07-2016 10:46 AM
Had same problem on win7 pro64. I think it only appeared after I activated the network capability. Tried to go back to USB but problem remained. Tried reinstalling everything, firmware updater, driver update....no joy. UNINSTALLED IJ NETWORK SCANNER SELECTOR EX (via windows control panel) and problem seems to be fixed. Don't know if Network capability works and don't care.
07-02-2016 09:22 AM
I am on Windows 10 and getting the same error through Wireless and when I connect directly through USB I get the same error. This was working, I did not change anything and now I can't scan at all. I tried Paint and that did not work. I have a ton of pictures to scan and am really unhappy that this is no longer working.
07-02-2016 09:32 AM
I have the scanner selector running and still I'm getting this error message.
07-08-2016 10:51 AM
I had the same problem and find out the printer was just offline:
Uncheck your "use offline" settings in printer's config. You can also right click your printer, in Control Panel, access Scanning Properties as Admin, and click "Test Sanning". Windows will activate the printer .
Hope it helped!
10-19-2016 07:56 AM
After trying your workaround, I tried running the Canon scan again and it worked!
10-29-2016 04:25 PM
I currently have a problem with my Pixma MG2922 where the scanner won't start. I have a Windows 10 laptop; what's a solution to the problem i am currently experiencing.
