06-23-2013 08:47 PM - edited 06-23-2013 08:49 PM
I can only find the option to save scanned documents in the PDF format. I want to know if there is a way to save in Word. Can anyone help me? Canon Printer MXZ5420.
06-25-2013 12:00 PM
Hello Yvonne.
Specialized OCR software may be needed in order to save files directly to Microsoft Word format. Our software does not have this capability.
If you are attempting to scan a basic, text-only document. You can use our IJ Scan Utility to scan and make adjustments.
1. Start, point to (All) Programs, Canon Utilities and then open the Canon IJ Scan Utility.
2. Click 'Settings' on the lower right corner.
3. Click 'Document Scan' on the left.
4. Under 'Application Settings' on the right, select 'Start (OCR)' and choose 'Canon My Image Garden' in the menu.
5. Click OK.
6. In the IJ Scan Utility, click 'Document'.
When scanning is completed, Notepad will open and you will be able to edit and save your document.
05-12-2014 10:48 PM
Hi, Yvonne.
Why not installed some PDF scanners to help you scan PDF files directly? Or you can convert PDF to Word doc using OCR. But I do think the PDF scanner is necessary for us. Isn't it? Whatever, I hope you success. Good luck.
Best regards,
Arron
