PIXMA TS3522 black ink will not dry after 48 hours
Lt72884
I currently have the TS3522 series printer. I am using the 100 pages per month plan for ink. However, i have noticed when printing on glossy photo paper (8.5x11) the black ink never dries. After 48 hours, i can rub off all of the black ink on the print. However, all the color ink dries immedicably and stays on. Its only the black ink that comes off.
In the attached image, notice the black rubs off but not the color. I need this fixed ASAP as we use this printer for business and we cant have the ink rub off. This is after 48 hors of allowing it to dry.....
I also tried to switch the paper type to photo paper but there are ZERO options for 8.5 by 11 inch paper.. Only had 6x4 option which is ridiculous for 2023 printer. I would expect that of a 1980s printer but not a modern printer at all.
2 REPLIES 2
SamanthaW
Moderator
Moderator
Hi there!
Can you please check which model within the TS3500 series you are working with? You can see either on the top or the front of the printer itself, you might have to lift the paper tray to see it! This will help the Community better help you.
If this is an urgent matter, please check out your support options HERE.
Thank you for noticing that. I have edited the post
