03-25-2021 10:39 PM
In the past 8 months my printer will not print text. My laptop recognizes the device (Lenovo Thinkpad Edge 520) with a windows 10 upgrade (original ops 7), engaging the print function will activate the printer, it will inject paper, the ususal printing noise will occur, eject the paper but, there will be no printed text. Sometimes it will print email addresses/links from a MS Word doc (they are hot links in the doc). On occasion, graphics will print from a PDF but, no text from the doc. I have uninstalled and reinstalled, diagnostics test results return in a "Ready Status", and I have made changes in "Properties Dialog" to no avail.
I have been informed that there may be a Windows 10 update that caused some issues with personal (the low end ones) printers. A friend with a Brother personal printer was able to restore theirs to operational by deleting the particular update. That did not work for me.
Seeking possible solutions, the scanning works fine. Copyiing will not work as well (printing required.
Please advise,
Anthony
03-26-2021 09:22 AM
When a printer doesn't print text, across multiple file types, it usually means there is an issue with its driver (wrong or incorrect) one being used.
Did the printer work correctly under windows 7?
Did you reinstall if after upgrading to windows 10?
How is the printer connected? (USB or wireless)
Start here:
Perform maintenance, print a nozzle check pattern. Does this print correctly?
Next step:
Remove the device from Control Panel > Device and Printers (just right-click and select remove from the context menu).
Now uninstall the printers drivers (all of them) form Control Panel > Programs and Features
Reboot your computer
Drivers for Windows 10 are here:
Support | MG Series | PIXMA MG2520 (MG2500 Series) | Canon USA
Now use the MG2500 Full Drivers and Install Package from the link above to reinstall your printer.
03-26-2021
12:31 PM
12:35 PM
Hello Rick,
I have uninstalled all components and reinstalled with the download from the reference link that you sent (full package and drivers). I used that download days before I posted on this site.
The printer was working after the conversion to Windows 10 years ago. This problem just surfaced 3-4 months ago (approximate, the upgrade to Win 10 was 2015-16 when it was free).
The printer worked fine with Win 7 and 10 (until recently)
I did not reinstall the printer after upgrade because it was working fine until recently
I took the other steps you suggested before I posted to this site
I have printed to "Print Head Alignment" pattern during installation. I does not print the arrow in the upper left corner of the printout. I does print colored columns in a certain pattern (see attached)
The printer is connected via USB
The printer was purchased Nov 2014
Here is the nozzle check pattern
Here is the Guide Pattern from the menu
I appears that I may have a clogged nozzle for the black ink. What do you think? Does mean JUST REPLACE THE PRINTER?
i await your response.
06-17-2021 06:41 AM
06-17-2021 06:43 AM
06-17-2021 02:33 PM
Thanks Angie68,
After all that trouble shooting that I did, it came down to replacing the ink with Canon Brand cartridges. A friend in Florida advised that other than Canon products can cause issues and I read that Canon includes updated firmware with ink replacements. The printer has been working fine since the new ink was installed.
I appreciate the input.
