Canon MG6800 prints only blank pages
StefanS
I hadn't used my Canon MG6800 for a while.
When I tried to use it today, the 1st time I printed I only saw some vague black stripes on the paper. The next several times I printed, the printer only printed out blank pages.
I've tried cleaning, deep cleaning and print head alignment, but nothing is helping
What can I do to solve this? Is my printer broken or would replacing my cartridges help? Note: I'm using unofficial cartridges that have always worked fine (except now)
5 REPLIES 5
How long has it actiually been since you used the printer?  "For a while" is pretty vague.
Inks can dry up, and the print head can become clogged with dried ink which can keep the printer from outputting pages with images or text.
Typically a deep cleaning can resolve or at least help, but sometimes depending on conditions / other factors...  time since last use, where the printer is stored (temperature, environment) etc can cause more serious problems.
What happens if you try the copy or scan function?  Any output?
This should rule out a problem with the driver or device the printer is connected to.  If there is no output, its likely the inks or the print head. (dried up or clogged)
StefanS
Thanks for your reply!
I hadn't used the printer for about 3 months.
Yes, when copying the issue persists. How can I find out if the issue is in the print head or on the inks?
Not any of the 5 colours are being printed btw
Hi StefanS.
Were you able to run a deep cleaning of the print head? If not, please follow the instructions at the link below:
Deep Cleaning the Print Head
If the issue remains, I recommend replacing the cartridges, as it is possible that they may have dried up.
StefanS
Thanks for the information! Deep cleaning the print head doesn't work, so I'll probably buy some cartridges
Nauguste
I'm on the same boat. Except I've done EVERYTHING- Deep cleaning, new ink cartridges etc... No black & white only printing- It's as if I have no black ink cartridge in there. The copy function does not work at all. Prints blank pages. Any suggestions please?
