02-21-2016 10:15 PM
I recently changed the name of my wifi. I connected the printer to the access point and selected the new wifi name.
But just today, my printer just prints blank pages. Could the changing of wifi name cause the blank pages? It's receiving the data that something needs to be printed. It's just that there is nothing on the paper.
02-21-2016 10:25 PM
Hello Vndnsms!
To have a better understanding of your issue, please let everyone know what operating system (Windows Vista/7/8 or Mac OS 10.X) you are using. That way, the community will be able to assist you with suggestions appropriate for your product.
If this is a time-sensitive matter, our US-based technical support team is standing by, ready to help 24/7 via Email at http://bit.ly/Canon-Support or by phone at 1-800-OK-CANON (1-800-652-2666) weekdays between 10 AM and 10 PM ET (7 AM to 7 PM PT).
Thanks!
02-22-2016 10:22 PM
I tried printing on both my mac and windows computers.
02-23-2016 09:07 AM
Hi vndnsms,
First, please make sure that the ink tanks are installed in the printer correctly and are in the correct order. The order from left to right is as follows:
CLI-226BK
CLI-226M
CLI-226C
PGI-225PGBK
CLI-226Y
Next, a test of the printer should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the PIXMA MG5320 and follow these steps:
1. Press <HOME>.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this post. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
1. Press <HOME>.
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly?
If it does not, please contact our support group using the following link:
http://www.usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
10-11-2017 09:25 AM
Hello,
My MG5320 will only print blank pages. I have tried every troubleshooting tip. I just spent $70 (!) to replace the cartridges, so it definitely has ink. It makes all the sounds as if it is printing and runs the paper through, but there is nothing on it. Trying to run a nozzle check pattern or any other maintenance yields the same result.
The printer seems to be operating fine, so I suspect that Canon has simply decided not to update or support the drivers so that we're all forced to buy new printers. I can guarantee you that whatever I buy, it won't be a Canon.
05-20-2020 05:05 PM
09-14-2021 08:20 PM
Me too - and I just changed the name & password for my router
