02-15-2017 07:53 AM
I'm having a problem with my printer printing photos with a purple hue. I have tried all the maintenence/cleaning functions, replaced all the ink cartridges and uninstalled and reinstalled the printer several times. I've performed checks and it says it is installed properly etc. I can't figure out what the problem could be. It was working fine a few weeks ago. Please help!
02-15-2017 12:06 PM
Hi mmelanson,
First, please make sure that the ink tanks are installed in your PIXMA MG5220 correctly and are in the correct order. The order from left to right is as follows:
CLI-226BK
CLI-226M
CLI-226C
PGI-225PGBK
CLI-226Y
Next, please print a test page from your PIXMA MG5220:
1. Press <HOME> on your PIXMA MG5220.
2. Rotate the menu to Maintenance and press <OK>.
3. Press <OK> on Print nozzle check pattern.
4. Press <OK> on Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this post. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
3. Press <OK> on Cleaning.
5. Press <OK> on Yes.
After a few cleanings, please print another Nozzle Check.
Does the Nozzle Check print correctly?
If your PIXMA MG5220 continues to print incorrectly, please contact our support group using the following link:
http://Canon.us/ContactLI
