12-09-2016 04:58 AM
Canon MF6100 UFRII LT
sent a print test page from Right Click printer properties dialog
printer using its own installed Canon MFNP Port
Including the MF6180dw all is set to factory reset
the test print page job came out after 2 minutes
the led was solid continous green on the printer but i could not see the print job in the Job Status in the printers web console or in the Device s print queue in Windows either
on the printer LCD it was Printer Waiting to Print
Another test on the same machine
Sent 1 page from chrome browser of an article to the same default printer ( UFRII LT)
Solid green on the printer continous
cant see the job anywhere ( not in printers web console in jobs status not under windows)
at 1 minute some mark printer did one clack moving noise like when it starts something but all it was is a second after nothing
On the printers LCD Printer Waiting to Print
After finally 12 Total minutes the machine started to make the regular noises and printed the page
Another test under outlook a simple email only text took 3:45 minutes to come out eventually
I tried from under Mac OS X , and Ubuntu and I got the same/similar results.
Strange is before i had no issue with this printer at all , always printed everything quick no problem.
I was also able always to see the pending/ongoing jobs under Job Status in the Printers web panel - no not anymore
However completed jobs even if after 12 minutes they appear in the Job History tab with the details correct
what can be the issue? Do I need Canon Service to have a look and change something inside?
it has less than 12 months this printer. I just finished the toner it came with ( low capacity one) and started a new original 719H toner in it (printed a few pages only)
