03-14-2014 12:48 PM - edited 03-14-2014 12:49 PM
How do I change the country? My paper sizes are all European and I need US sizes?
03-14-2014 01:31 PM
Hi csimps01!
Welcome to the Canon Forums, and thanks for your inquiry!
So that the Community can help you better, we will need to know exactly what Canon model you're using, and the Computer Operating System you're using (Windows XP/Vista/7/8 or Mac 10.x), as well as the way you connect to your device (USB or networked via WiFi or Ethernet).
If this is an urgent support need, please CLICK HERE to reach our friendly Technical Support Team.
Thanks and have a great day!
03-14-2014 01:37 PM
Hi It's MX459...using Windows 8 with a USB...Thanks!
04-10-2014 05:47 PM
Hi csimps01,
To change the country setting on the printer, please follow these steps:
1. Press the Setup button. The Setup menu screen is displayed.
2. Use the left/right arrow buttons to select DEVICE SETTINGS, then press the OK button.
3. Use the left/right arrow buttons to select DEV. USER SETTINGS, then press the OK button.
4. Use the left/right arrow buttons to selet COUNTRY OR REGION, then press the OK button.
5. Select the applicable country using the arrow buttons, then press the OK button to save the changes.
Hope this helps!
