12-03-2017 10:06 PM
I am using Canon MX432 Printer/Scanner which was working fine till I updated os to Windows 10.
After installing driver for Canon MX432, my printer started working fine. But Windows is still not recognizing scanner.
I tried using IJ Network Scanner Selector but no use.
Somebody suggested MP Navigator, but I do not find version for Canon MX432.
Error that scanner gives is "PC not connected".
02-02-2018 04:02 PM
Hi, anujadalal,
Let's test the hardware by initiating a scan from the computer.
Type "IJ Scan Utility" in the search box in the lower left of the screen.
Open IJ Scan Utility.
Place your original.
Press the "ScanGear" button.
Press "Preview."
If you are happy with the image, press "Scan" to complete the operation.
Are you able to acquire an image?
12-05-2018 08:18 AM
Hello,
I have the same problem. Unfortunately, when I run the utility, the 3600 series printer from my second home is the only printer available.
Help & Thanks!
12-05-2018 10:48 AM
Hi bcalski,
So we can assist you, we will need to gather some more information. Please write back with answers to the following questions:
12-06-2018 08:10 AM
Hi Arthur,
I'm running Windows 10.0.17134.407. My printer is connected via WiFi and prints fine.
Thanks for your quick response!
12-11-2018 04:45 PM
12-13-2018 10:45 AM
Hi bcalski,
If the printer is not listed in IJ Scan Utility, the scanner driver may not have installed correctly. Please remove the printer from your Windows 10 computer and then reinstall the driver.
After you select the wireless connection option in the installer, a box will appear that shows the drivers installing. It may go by really quick but please let us know if you see the scanner driver install during the setup.
12-15-2018 09:00 AM
It does install. Here's the reswults:
Setup Results
Model :
Canon MX430 series
Network Setup of the Printer :
Completed
Name :
Canon MX430 series Printer
Port Name :
CNBJNP_888717C17E82
Network Setup of the Scanner :
Completed
Name :
Canon MX430 series(88.87.17.C1.7E.82)
Network Setup of the Fax :
Completed
Name :
Canon MX430 series FAX
Port Name :
CNBJNPFAX_888717C17E82
Network Type :
Infrastructure
SSID :
12-18-2018 04:07 PM
It does install. Here's the results:
Setup Results
Model :
Canon MX430 series
Completed
Name :
Port Name :
CNBJNP_888717C17E82
Completed
Name :
Completed
Name :
Port Name :
Network Type :
Infrastructure
SSID :
12-19-2018 10:19 AM
Hi bcalski,
Since the scanner driver did install, I would like to see if you can scan from paint. This will allow us to test the scanner driver since the printer is not listed in IJ Scan Utility.
To scan from paint, please open paint on the computer and select "File" in the upper left hand corner. In the drop down menu select "From scanner or camera" and try to scan from there. Does the image scan?
