06-06-2021 06:41 PM - edited 06-06-2021 06:42 PM
I have two computers in the same room.
Both are running Windows 10 and share the same internet connection wirelessly.
They are currently sharing one Canon MG2520 printer by moving the one USB cable back and forth.
I have already set up the printer as a shared device on my PC.
But when I click on Add Printer, the laptop doesn't see it .
What am I doing wrong?
06-08-2021 10:08 AM
Try searching for the computers hostname from the laptop.
\\computername\printername
~CarePaks Are Worth It
06-14-2021 09:32 AM
How do I do that?
07-03-2021 10:35 AM
09-16-2021 02:51 PM
I still have the same problem.
Can anyone help, please?
06-23-2022 05:16 PM
06-23-2022 11:21 PM
The MG2520 only has a USB interface. Its really designed to be used / connected directly to one device. Its possible to move a USB connection between devices as well, but its not as convenient.
In a network environment, the printer can be connected to to one computer and shared. This allows other networked computers to print with the following limitations. The PC the printer is connected to must be turned on for the shared printer to be accessible.
Once the printer is shared, it can be added to another machine using the add printer dialog.
Using the example I provided above.
The computer name is the "host name" of the computer the printer is physically connected to via USB. The printer name is the share name of the printer you can specify when you enable sharing for the device. Again, on the computer the printer is physically connected to.
Other possible solution. Consider purchasing a true network capable printer. You may find it more convenient than having to deal with a USB connection, a device that always has be be powered on and the other quirks that come along with managing what is really an unreliable way to print from multiple devices.
Hope this will be helpful.
