02-20-2014 02:00 AM
03-15-2014 08:55 PM
This was all my bad, I selected the wrong driver version :((
Thank you anyway
03-15-2014 08:08 PM
Hi slimfit,
Do you have another USB cable that you can use to connect the printer to your computer? Also, if you disable any antivirus or firewall software that you have on your computer and then attempt to reinstall the printer, does it install successfully?
If this is a time-sensitive matter, additional support options are available at Contact Us.
03-15-2014 08:55 PM
Thank you anyway
04-02-2017 01:04 PM
my printer says the paper and the ink is wrong. i have everything set.
