07-29-2015 08:06 AM
Can anyone help me with these issues?
We are a small historical society and use a Canon Microfilm Scanner 300 II. I have seen on Canon's website a table that implies that the latest Capture Perfect software to work with the 300 II is patch v1063 and that the 300 II is apparently not supported above Windows 7.
Can anyone confirm:
If the 300 II is not support beyond Windows 7?
If patch v1063 is the latest Capture Perfect software to work with the 300 II?
Can anyone tell me if they know of a table showing all the versions of Capture Perfect and what OS they run under?
I am trying to install the v1063 patch to our capture perfect software. This appeared to work fine but when I try a scan to page I get "No devices found." I also get "Cant locate SCSI device; check cable and power.(-4536). I am using a USB port not SCSI. In the control panel under devices and printers I see under Unspecified an entry for Canon USB adapter for MS with a triangle and an exclamation point in the triangle. When I perform the Troubleshoot function the system determines the Canon USB adapter for MS is not installed but when I click apply the fix it cannot find the driver.
Can someone help me with this and explain how to install this driver?
Thanks,
Kurt
