11-22-2012 07:56 AM - edited 11-22-2012 08:08 AM
The new computer I bought comes with Windows 8 and I can't upload the photos from my Rebel XSi now. I installed the software that came with my Rebel (ver 17.1) but it must be outdated. Or is there a different reason?
If it's the outdated software, can someone please direct me to the new downlad link? Here's the link to the only information I found - which isnt much or helpful:
Thank you - and happy thanksgiving.
09-20-2013 01:37 PM
you the man
worked perfect first time
whoooooo hooooooooo
10-02-2013 10:59 AM
I have a Rebel Xti, I see all the colored icons on the menu, but there is no option for communications on the 2nd amber set up icon 😞 I wonder if it isonly on the XT??
02-02-2014 05:18 AM
10-02-2013 11:04 AM
10-02-2013 11:45 AM
Hi Colleen,
Unfortunately, I only have an XT and am still stumbling around that. Can't help with the XTii.
10-04-2013 05:56 PM
Hello Colleen,
The EOS Rebel XTi does not have a communication mode. It should be able to make a direct connection to the latest operating systems. Since you mention using the SD card, it would be worth noting that downloading direct from the SD card, either via a memory card reader or through your computer directly, would be the most direct method.
09-26-2015 11:36 AM
@Tim wrote:Hello Colleen,
Well, that's interesting. With all the recent talk about how early Rebels have to be told to use the Picture Transfer Protocol (or whatever it's called), I've been wondering why I couldn't find it in my XTi manual.
Does the XT really use SD cards? The XTi does not.
09-23-2015 11:34 AM
Perfect! worked first time. Thanks
01-09-2014 04:43 PM
I uploaded the new utility software but my problem persists; my problem is that Windows doesn't even seem to find the camera (doesn't beep or show up on the My computer screen); I tried other USB devices in the USB slot and they work and I tried the camera/cable on a windows 7 system and it worked fine. I tried troubleshooting devices but it said there were none. What am I missing?
01-09-2014 06:50 PM
I FOUND OUT THAT i CANNOT USE THE eos UTILITY BUT IF i CONNECT THE CAMERA DIRECTLY TO THE COMPUTER IT DOES WORK.
