Why does DPP4 crop my images when opening them?
Paul-1553
When I open a CR3 image in DPP4 version 4.17.10.0, the image appears to have been cropped, that is ~5% of the top, bottom, LHS & RHS is missing with no way to retrieve it. Do I have an incorrect setting or have others had this problem?
20 REPLIES 20
Attached is one image which I believe shows the issue clearly. It contains the original CR3 file which I can see is not cropped when viewed in Adobe Bridge. When I load the file into DPP4 it appears cropped on my screen and when I save a JPEG version, that version is cropped when viewed in AB and also in Picasa. Saving a new CR3 file results in an uncropped image again when viewed in AB.
https://www.dropbox.com/t/u2VVIXxiAukO24Qo
Seems like distortion correction you can't turn off.
Even if they report the same resolution the one exported from DPP is "closer". darktable to the left and your exported file to the right. The embedded JPEG is same as your exported JPEG.
Skärmbild från 2023-04-18 19-14-35.pngSkärmbild från 2023-04-18 19-14-35.png
jrhoffman75
It looks like you have in-camera lens corrections applied:
Lightroom and Bridge do not read those parameters but DPP4 does. Run a test on a subject with and without in-camera corrections and see if that explains it.
From exiftool, information about the crop.
  • [MakerNotes:Image] Sensor Width : 7128
  • [MakerNotes:Image] Sensor Height : 4732
  • [MakerNotes:Image] Sensor Left Border : 156
  • [MakerNotes:Image] Sensor Top Border : 84
  • [MakerNotes:Image] Sensor Right Border : 7115
  • [MakerNotes:Image] Sensor Bottom Border : 4723
  • [EXIF:Image] Exif Image Width : 6960
  • [EXIF:Image] Exif Image Height : 4640
IBIS will move the sensor changing those margins to get the advertised image size. Making several images in a row hand held might frame all the images the same while changing the margins. Other software might not read that information and crop it differently than does DPP.
For the "Why?" question, my guess is that it was based upon an engineering expectation that only that portion of the sensor chip would always be properly illuminated by the lens or maybe a requirement to produce an image with the advertised dimensions. For this particular lens, it is possible that more of the sensor chip is illuminated at wide angles than at telephoto.
johnrmoyer
Maybe DPP crops it in an attempt to match what was in the viewfinder? With IBIS the sensor chip will move changing the margins.
Thanks John - I tried with and without the corrections and cannot see any difference in the cropping of the 2 images.
Thanks John, I just took a couple of test shots and I think that you are correct, DPP shows what I see in the viewfinder, the CR3 out of the camera and Bridge appear to show additional pixels to what I see in the viewfinder.
Paul-1553
Thank you all for your inputs - much appreciated!
dougsmit
I suspect this is related to my question asked here on CC and not answered.  I use DPP4 to convert CR3 to TIFF that will be focus stacked using Zerene stacker.  This can be 2 to over 200 images and ALL must be exactly the same size to the pixel.  Not selecting a resize option often produces a 1-2 pixel change part way through the group and this causes Zerene to reject the job.  When you do resize you are given a default setting for horizontal and vertical but this is not the same as the published image size as shown on the other DPP4 pages (6960x4640 for the R7, for example).  My question is why?  I see the possibility that it relates to IBIS or even some factor of lens correction in the software.  Specifically, should I select those defaults or change them to the 6960x4640 for best results?  When shooting focus brackets we must be sure that both ends of the series are fully on the frame (which end is a problem depends on whether you used the in camera focus bracketing routine or advanced the camera toward the subject using a slider like Miops or manually just by leaning toward the subject as you shoot).
I have never used Zerene stacker. I use DPP or hugin to stack. I have EOS R5 and not R7. I hope some of this might help anyway.
I always see the same image size starting point in DPP unless:
  • I have done compositing in DPP
  • I have distortion correction enabled in the camera
  • I enable distortion correction in DPP
  • I have cropping enabled in the camera
I do not remember, but auto lighting optimizer or portrait lighting might make a difference.
exiftool -imagesize *.CR3
will report the size in the raw files.
exiftool -sensor*border *.CR3
will report some of the cropping hints that the camera puts into meta data.
I have not tried, but I expect that exiftool can also write other numbers to those values. This is complicated if the value exists in more than one place.
