07-15-2023 08:09 PM - last edited on 09-26-2023 08:27 AM by Danny
I am having issues connecting my R8 to my Mac via the EOS Utility. I have the latest software and have gone through the user manual. The message I keep getting is:
"Communication with the camera via USB cannot be established.
Start EOS Utility after closing all the apps that communicate with the camera, and then turn on the camera again."
I am unaware of any apps that I have that would be trying to communicate with my camera in the background. Anyone know what's going on? Thanks in advance.
07-16-2023 02:11 PM - edited 07-16-2023 02:19 PM
@tjdowling wrote:I am having issues connecting my R8 to my Mac via the EOS Utility. I have the latest software and have gone through the user manual. The message I keep getting is:
Start EOS Utility after closing all the apps that communicate with the camera, and then turn on the camera again."I am unaware of any apps that I have that would be trying to communicate with my camera in the background. Anyone know what's going on? Thanks in advance.
It is a problem that seems to have developed with the 13.4.1 update to Ventura.
I was able to sync my 1D X MkIII prior to that update and now I get that error.
If you are only looking to download images you could get a card reader. If you are wanting the tethering features then we have to wait for Apple to fix the problem.
07-15-2023 08:19 PM - edited 07-15-2023 08:20 PM
Make sure that Wi-Fi and Bluetooth are turned off in the camera in order to use the USB cable.
07-15-2023 08:28 PM
No luck
07-15-2023 08:45 PM
Are you using the USB cable that came with the camera? If not, make sure that the cable is a data cable and not a charging only USB cable.
Also, what is your Mac operating system version? Someone else here will have experience with a Mac, as I use a Windows computer.
07-16-2023 10:41 AM
Yep - the one that came with the camera.
MacOS Ventura.
07-16-2023 01:57 PM
Maybe this is a privacy & security issue? On your Mac, launch System Settings and then choose Privacy & Security. Scroll through its settings and see if there's anything related to attaching accessories.
This Apple Support article has some details.
07-16-2023 02:49 PM
This is appears to be a setting only on Mac's with the M1/M2 chip. I have an Intel Mac and don't have the setting. Good suggestion though. Thanks.
07-15-2023 08:48 PM
If you are just trying to transfer pictures to your computer, you could remove the memory card from the camera and use a card reader to transfer the files.
07-16-2023 05:31 PM
Sounds like either Apple or Canon would need to provide the solution via an update of some kind and I'm not banking on the speed of Canon updates...
