R5 New Firmware 1.8.1
tangogal
My Canon R5 has firmware 1.7.1. I got a notice that new software is available but when I put in my Os system (Monterey 12.6.3) it recommended my existing firmware. I see that 1.8.1 is available for download also, although not what was recommended. I am wondering if I download it and install it, will I still be able to shoot in raw? Will I have to use Photo Professional instead o Photoshop for any images taken in the higher resolution format? I am wondering if I really should install this new firmware.How do you instruct the camera to not use the 400 px format and shoot in raw?
6 REPLIES 6
johnrmoyer
Whiz
Whiz
Thank you. I see now you can disable it. With all the cautions about putting it on a tripod, not shooting moving images, etc.  I wonder if it's worthwhile to install it unless you are doing still life, studio work or landscapes you wish to blow up very large.  Does the 1.8.1 firmware do anything useful other than this high resolution imaging?
Yes.  You will still be able to shoot in RAW.  The new FW will add the (Ibis High Resolution) PS option.  See @JohnMoyer's link below.  When enabled the resulting output (file format) is jpeg. You will not lose any function.  Its possible to open these files in another program.
Usefulness depends on the individual.  Some think wow, pretty cool.  Ohers, meh, I won't use it.  Its likely Canon also included some under the hood fixes.  It doesn't hurt to have it and I've not heard anything negative about it impacting functionality.  Turn it on when you want to use it, leave off for normal single shot RAW shooting.
Thank you.
Ive tried all that and it still will not work. Do you have any more suggestions?
