08-20-2024 12:23 PM
Have been using DPP for years. Recently the "properties display" stopped being changeable. Just allows the same five default display parameters. But lenses never shows. I used to like the display to see what parameters or setting I messed up on. Now it can never be changed. I tried everything I could think of to get it to work again. Uninstalled software. Went back to older version. Still inoperable. Using Windows 10. Use Canon R6 and R5. Baffled.
08-20-2024 12:30 PM
Figured out what I was doing wrong. There is a menu flydown.on the preferences menu.
Below Properties to display you must pick the third item
"Display settings for preview properties."
08-20-2024 12:30 PM
