07-03-2022 11:21 AM
When I try to use the eos utility software it says i have to change firewall settings. but when I do it does not work.
I have allowed several apps trough the firewall via the control panel but it still does not work.
any help is appreciated
07-03-2022 11:36 AM
You seem to be having an issue with the MS Windows OS. Are you running the latest version of the EOS Utility?
Which application did you run? In the START menu this a "Canon Utilities" folder, which contains an app simply named "EOS Utility". This is the app that launches the LAN pairing process.
07-03-2022 04:18 PM
I am running the newest version (3.15.0.11) but I also tried .13 but that also didn't work.
I ran the EOS Utility app yes but it still does not want to work.
This appliciation right?
Thanks in advance
07-03-2022 06:50 PM
I do know what “it doesn’t work” means. Does that mean program does not even start?
07-03-2022 08:02 PM
Go into the EU3 folder and double click EOS Utility 3. See if that works better.
