12-25-2020 03:57 PM
So, need help
Own a Rebel SL1. Downloaded the EOS webcam utility. Rebooted computer.
When I plug the camera in and go to zoom, a variety of things happen.
1. Either a blank screen
2. The EOS webcam utlity logo.
3. Then, when I try to click start video, I get yellow text boxes in the corner "Failed to connect to camera, choose another camera".
The EOS Utility is not running in the background, it is not in the system tray. When I run task manager, it is not showing as open/running.
The SL1 has no WiFi, so thats not the issue either.
Any thoughts???
12-25-2020 04:09 PM
@brclinn wrote:So, need help
Any thoughts???
Is the SL1 supported by the webcam utility? If so, is the SL1 in video mode?
When you run the regular EOS Utility, are you able to use it for remote shooting with the SL1? If not, that's the problem.
12-25-2020 07:35 PM
According to the Canon website, the Rebel SL1 is supported.
I do have it in video mode.
I've never run the uitlity before, just downloaded today becasue my laptop camera won't work. Need a webcam, figured my Canon could do the trick.
12-25-2020 09:49 PM
Your camera appears to use the EOS 2 Utility. However, you need to install EOS 3 to get the most current versions of either EOS 2 or EOS 3. There is only one install package for Windows 10, and it seems to install both.
You may have a bad cable. The regular EOS Utlity is a much simpler app, which does not really on others in order to work. It is a good test of your cable and connection to your camera. Besides, the EOS Webcam Utility seems to need to have it installed in order to work properly, or at least the Beta versions did.
12-28-2020 11:18 AM
