EOS cameras not recording to memory cards when using EOS Utility remote shooting
sparkycpg
Enthusiast
I have not used the EOS Utility for remote shooting for a while now.  I was was sure that the camera both recorded the images to the local camera memory cards and to the remote connected computer HD simultaneously.  That is not happening now and I cannot find any setting to change it.  It is only recording to the remote computer with both my EOS R5 and EOS 5D Mark IV.  Did something change in the software of am I just not remembering things correctly?  I downloaded the latest version 3.13.20.4
FloridaDrafter
Like you, I haven't used it for a year or so, but there used to be an option where you could select computer, card, or both. I just put together some old screen grabs from 2019. Maybe it's still this way... Just not sure.
17 REPLIES 17
FloridaDrafter
The latest version of EOSU only saves to the computer.
Thank You. This setting still exists in the current version. I don't remember have to change this in the past. I think it was default.
Thanks! EOS version 3.13 (The current version, I believe) works exactly like you have so clearly described.
[ deleted ]
But, what happens when you use Remote Shooting in DPP4?  I thought DPP4 was how Canon wants you to do it now.
@Waddizzle wrote:
[ deleted ]
In Windows 10, if you click on Remote Shooting in DPP4, it opens the EOS Utility but also gives you a dialog box to select a folder for your shots. Since I don't use DPP to remote shoot, I just clicked "Remote Shooting" without a camera attached. If you just connect your camera to your computer, you get the EOS Utility options window. I'm not sure why some folks think the EOS Utility won't allow you to select a file destination. It clearly does in Windows 10, and IIRC, you can make it open files with DPP.
In my original reply, I hadn't used it for a while, but I have been recenty, to shoot birds at our feeder using a 30' USB cable. Attached is a recent screen cap.
Newton
@FloridaDrafter wrote:
@Waddizzle wrote:
[ deleted ]
Newton
I do not think it opens up the EOS Utility, per se.  It is opening up the same GUI used by the EOS Utitlity, with additional options on how to save the files.
Good info newton.
Several years ago, when I had my 1D Mark IV someone posted here that EOSU would not save to camera, only computer. I answered that is does and posted this:
I was challenged for my answer and told that EOSU3 no longer allowed that and posted an earlier version of this page from EOSU manual:
Since I don't use remote shooting I have always accepted that person's response as correct.
No where that I can find in the EOSU3 manual is there a note or discussion similar to the EOSU2 manual.
I totally understand, John. It's hard to wade through info sometimes, and I am probably the worse at taking the first thing I read as being gospel. My wife's favorite saying to me is "why don't you read the instructions (or manual)"?
You always do a great job at providing reliable info and links 🙂
Newton
