10-18-2023 01:34 PM
The path of our project is very long and it takes a long time to drill down through the folder browser. The current browser window also does not display the Windows 'Quick Access' list so there's no workaround that way.
Thank you!
10-18-2023 05:01 PM
The Folder Browser Dialog Window is built into MS Windows. That means it is not part of the Canon applications. The same dialog window is used by multiple applications to select a folder.
This is only a user forum, not Canon Support. You should contact Canon directly with any and all product suggestions that you may have.
