EOS Utility: RAW images are Renaming When downloading to PC
jmgimpe
This problem has just started in the last two weekends that I went out shooting.  I shoot with a Canon R6.
I was shooting wildlife so I was using continuous shooting and holding the shutter in short bursts.  I did not look at the image numbers while the images were on the card in the camera.  I use EOS Utility to download the images from the camera to my PC (I do not take the SD card out to download).  The images get downloaded to my Photos folder into a sub-folder named with the date of the shoot.  So if I have 2 days of shooting on my card, I will get 2 sub-folders, one for each date of the two day shooting.
When I opened the directory for 01_25_2025, the image numbers were all messed up.  Here is an example - _MG_0001.cr3, _MG_0001_1.cr3, _MG_0001_2.cr3 etc.  These are not duplicates.  The 0001 is the start of one group of continuous shooting of an eagle.  The 0001_1 is the start of another group of continuous shooting of the same eagle at a different zoom, etc.
In the screenshot below, you will see the first 8 images are different zooms and bird positioning and the 8th is of an owl.  These are all in the _2 set of images, because I did shoot continuous shooting.  I have always done this for the last 2 years that I have owned this camera and had no issues with the numbering of my images.  They have always been numbered properly.
The _MG_0001 and _MG_0002 and _MG_0003 etc are the same group of images that I took continuosly.  The problem is the _MG_0001_1 should be the number after the first _0001 group ends.  So if the last image for the first group is _MG_0010 the next number for the the second groups first image should be _MG_0011.  It is not.  Now I have to make a batch file to rename these images and it is time consuming and easy to mess up the proper order (I already messed it up half way through making the file).
Does anyone know why this is happening all of a sudden?
The only thing I have done differently than I normally do is formatting my 2 SD cards.  I have always just erased the images from the cards.  Then 3 or 4 weeks ago, the camera took a long time to start whenever I first turned it on.  Then my friend said that it is probably because I need to format the cards to truly get rid of the image history.  After I formatted the cards, the camera started fine.
Oh yeah, the settings under the wrench are:
Record func+card/folder sel = Separate - Disable
                                                      Image Rec Options - Auto switch card
                                                      Video Rec Options - Auto Switch card
                                                      Image Record/play - 1
                                                      Video Record/play - 2
                                                      Folder - 100Canon
File Numbering = Continuous (should it be Auto reset?)
File Name = IMG_
Date and time = Jan 28, 2025 6:39:28
Firmware = 1.8.3
I did notice that my time was set wrong even though I know I made sure it was correct after the time change in the Fall.
Thanks for any help.
17 REPLIES 17
I format the cards in camera.  I also download the images while the cards are in the camera.  I did not change any menu settings.  The only thing I did a few weeks ago (just before this happened) was format the cards for the first time because my camera was slow to start when I turned it on.
March411
Do you have a card reader where you can format them through a computer? If you do you may want to give that a try.
I have the R6 MkII and had an issue with corrupt naming of the image file and that resolved it for me. I had always formatted through the camera, I moved (whenever possible) to the computer almost exclusively and have not had further issues. It may have been coincidence but worth a try.
Do you have an extra card you can test, see if occurs consistently with a different card?
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
I do have a card reader.  I can try that and see what happens on Saturday when I go out again.
March411
If all else fails jmgimpe don't hesitate to call Canon support. Over the past couple decades I have reached out for them and so far they haven't failed me. They even assisted in helping me get some conflicts resolved with Sigma lenses when I moved to the R system from EF. They are a real good group.
800-385-2155 or 800-652-2666
Marc
Windy City
Personal Gallery
March411
Hey jmgimpe, how did everything go this past weekend with you shoot?
Marc
Windy City
Personal Gallery
I was going to post yesterday and got busy with other things after work.  The numbering was good!  No _1, _2 etc.  Now, I don't know what was the solution.  So, when I plan to do a small shooting day (I had 4000 on Sat), I will try to format the cards in camera again and see if the numbering is messed up.  I formatted in the PC this past weekend.  The batteries were taken out on Saturday to charge them up, so next time I have a good charge left I will do a shoot and see if the numbering is still good.  Maybe it was a fluke before.
March411
Either way glad it worked out for you. It may have been a bad in camera format. I would be interested to know if it happens again after you format in camera.
Cheers!
Marc
Windy City
Personal Gallery
Thanks for your help.  I will try to remember to post my results.  Might be a couple of weeks though, as I will probably take a lot of images again this weekend and I don't want to have to try to rename all images if it goes bad.
