09-18-2024 03:29 AM
This has got to be one of the worst pieces of software ever. Come on, Canon! Why can't you get this right? Why is this so difficult for you? Why do I keep getting this error message every time I try to connect my R6 to my M1 MacBook Pro using EOS Utility 3? It is so frustrating!
09-18-2024 09:10 AM
Have you tried doing this when your MacBook is plugged in and not less than 20% battery?
When the power is critical, macOS likes to be stingy with where it allocates power, and USB is often one of the first things it cuts. Another issue that could be preventing your camera from connecting is the type of cable you're using. Believe it or not, there are several kinds of USB C cables that don't all do the same things. Some are power only, others transfer data very slowly, some are "normal," and others are Thunderbolt-rated. You don't need a Thunderbolt-rated cable, but you need a decent one that transfers data and power.
If you have tried a different, quality cable, and your MacBook is plugged in, and you're still having problems, give our team a call so they can troubleshoot with you. Support is at 800-OK-CANON (800-652-2666), Monday through Friday.
12-23-2024 10:59 AM
What USB-c cable is recommended? Is there a reasonably priced one on Amazon? The cables on that canon sells are way overpriced. Thanks.
