EOS Rebel T5 and Windows 10 Pro 22H2: Used to be easier to access card images
sbair
Using an SD card to upload images from a T5 to a business FB page. With the card I was using specifically for our store, the images I just took to post would simply appear on the computer screen when I connected the camera to the computer.  Then, I could select them and upload them easily. I used the camera for a wedding and used a different card for some images. Now, when I use the wedding card and connect the camera to the computer, I need to select the card and drill down to the images, find the images I want to use and select them. Is there some setting that I need to put into place for any card to work like my original card when I connect the T5 to the computer? I asked someone more tech savvy than I am but she could only help me find the images on the card from the wedding and then finding and selecting the images and inserting. The first card was so easy! Thanks for any help you can provide.
5 REPLIES 5
kvbarkley
You don't say what computer, but I think that once you have used more than one card you will have this issue.
Adding to kvbarkley's reply.  👍  In windows you can select the default behavior for Removeable Drives or Memory Cards.  The feature is called Autoplay.  >>>Settings > Devices > Autoplay.
These are your options
Thanks. I will give it a try and get back to you.
I’ll add it is a Windows machine. I think Lenovo. Can’t be upgraded to 11 so it’s a bit older.
Rick,
I tried these settings and they didn't resolve it. I'm going to get a new SD card and see what happens with that. Thanks for taking the time to reply. I appreciate it.
Sally
