EOS R5 firmware
manoucheri1947
I have difficulty with firmware update for my EOS R5. No problem downloading the file to my MAC desktop and then copying it to a formated SD card. However when placing the SC card in camera, setting mode to P, navigating to "wrench" and select ing page 5 for firmware update, the update version does not appear.
Any suggestion is appreciated. Wondering why a direct download is not available from website to camera, connected or wirelessly.
MM
2 REPLIES 2
Peter
Did you unpack the file?
Else you can download via Canon connect and update from your phone.
rs-eos
What specifically did you copy to the SD card using your Mac?  Typically, the firmware instructions call out to copy a file (e.g. .FIR) directly to the top-level of the SD card.  i.e. not placing it within any folder on the SD card.
Ricky
