09-12-2022 07:20 PM
Got a new laptop (with Windows 11 😞 ), Installed the Canon tools including EOS Utilities.
So I connect my trusty 70D via the special USB cable and expect the EOS utility to download my latest images to the laptop. But no
The EOS utility wants to find my camera on the network! When I connect my 70D via the (provided) USB cable. I get this popup that says "Application not installed. Please install EOS Utility 2".
It seems that the Downloads support site only includes EOS Utility 3.
What gives?
09-13-2022 11:27 AM
Keep loading more and scrolling down on the list.
09-13-2022 05:27 AM - edited 09-13-2022 08:08 PM
It seems Canon may have discontinued support for [EOS Utility 2]. Canon has not released a camera that uses it for several years. I recommend downloading and installing an older version of the EOS Utility 3.
Remove your current copy of EOS Utility 3 prior to installing an older version that runs on Windows 10. It may or may not run on Windows 11. If not, then you will need to use a card reader to read the memory card in the camera.
09-13-2022 07:37 AM
@sjmunroe wrote:Got a new laptop (with Windows 11 😞 ), Installed the Canon tools including EOS Utilities.
What gives?
Go to the EOS 1D X Mark III support page and download EOS Utility 3.13.10. It will install EOSU3 and EOSU2. Later versions of the installer only install EOSU3 (as you have found out).
09-13-2022 10:07 AM
Thanks for the tip. But when I login (select for 1D X Mark III) I only see version 3.15.20 and 3.15.10. I will look on my previous laptop.
09-13-2022 11:27 AM
09-13-2022 04:48 PM
That worked, Thanks
