12-20-2020 01:11 PM
uninistalled, cleaned registry, disabled virus checker, and dpp as well as eos lens reg tool loads, and then at the end NR without any explanation.
12-21-2020 09:14 PM
I appreciate all you have offered, I just found out through my computer specialist, that my operating sytem need a full "repair" as there is something wrong which needs to be fixed. I got a hint, when I tried to download Picture Style editor and it did the same thing. I will let you know the outcome when my computer is back to it's regular self. Thanks again
Millard
12-20-2020 01:24 PM
Windows 7 is not supported, and neither are the Windows 10 upgrades. You need a new computer. Microsoft dropped support for Windows years ago.
12-20-2020 03:17 PM
According to Canon USA support, 4.12.20 will work with Windows 7 64 bit as long as Microsoft Net framework 4.7.1 is installed.
Even the most recent release (4.13.10) will work with Windows 8.1 in addition to earlier versions of Win 10.
Not that Win 10 itself works that well...
Rodger
12-20-2020 04:04 PM
@wq9nsc wrote:According to Canon USA support, 4.12.20 will work with Windows 7 64 bit as long as Microsoft Net framework 4.7.1 is installed.
Rodger
The most recent version listed for Windows 7 that I see is DPP 4.11.
12-20-2020 05:19 PM
This is copied from Canon USA support site:
Driver/Software Details
File Name | dppw4.12.20-installer.zip |
File Version | 4.12.20.3 |
File Size | 283.41 MB |
File Languages | English | Spanish | German | French | Italian | Japanese | Korean | Russian | Turkish | Chinese |
Post Date | 04/07/2020 |
History | Changes for Digital Photo Professional 4.12.20 for Windows : - Supports EOS Kiss X10i / EOS REBEL T8i / EOS 850D. |
Environment | To use this software, your computer has to meet the following system requirements. 1. Supported OSes Windows 10 64-bit (Version 1607 or later), Windows 8.1 64-bit, Windows 7 SP1 64-bit(*) * With Microsoft .NET Framework 4.7.1 installed (Internet access required.) |
12-20-2020 05:19 PM - edited 12-20-2020 05:21 PM
Thanks, but net framwork 4.7.1 is loaded, and still "NR" on DPP .. I have a M50 camera, and the Version recommended for that camera was 4.12.20
Millard
12-20-2020 05:23 PM
Yes, this was all working at one time, but it must have gotten corrupted, and I tried to re-install after trying to uninistall (unsuccessfully). and it will not install.
12-20-2020 07:12 PM
It will not hurt to try this:
Fix problems that block programs from being installed or removed (microsoft.com)
Similar to Revo and CCCleaner, but made by microsoft for windows 7, 8 and 10.
I'm with the others. Windows 7 is EOL, and unless you have some compelling business purpose for 7 and are paying MS for support (translation) unwise business investment... it should be abandoned.
MS is still allowing free upgrade to 10 using your W7 or W8 product keys... (5 yrs later) so there is no reason not to install 10. If your hardware won't support 10, it shouldn't be considered or used for post production in the first place.
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
12-20-2020 08:42 PM
@wq9nsc wrote:This is copied from Canon USA support site:
File Name dppw4.12.20-installer.zip File Version 4.12.20.3 File Size 283.41 MB File Languages English | Spanish | German | French | Italian | Japanese | Korean | Russian | Turkish | Chinese Post Date 04/07/2020 History Changes for Digital Photo Professional 4.12.20 for Windows : - Supports EOS Kiss X10i / EOS REBEL T8i / EOS 850D. Environment To use this software, your computer has to meet the following system requirements. 1. Supported OSes Windows 10 64-bit (Version 1607 or later), Windows 8.1 64-bit, Windows 7 SP1 64-bit(*) * With Microsoft .NET Framework 4.7.1 installed (Internet access required.)
Interesting. When I select Windows 7 as the OS, the most recent version listed is DPP 4.11.0
Interesting. The results are mutually contradictory.
12-21-2020 09:14 PM
Millard
