07-23-2025 06:38 PM
HI all,
I do not see any distance data on the EXIF data in DPP. Is this possible?
Thanks!
Mike
07-29-2025 07:18 PM
Yes you are correct. It is the 580EX-II. It has the weather sealing thus the reason for the adapter. So are saying that I can see the settings in camera? I will try when I get the adapter. I did not think that was possible. It is a great flash!
07-29-2025 07:29 PM
Yes you can change the speedlite's setting from the camera's External Speedlite Control Menu. The last picture that is what my old 550EX displays since its old most settings are grayed out or missing. My 600EX II-RT displays the picture below when on my EOS 5D Mark IV. Your 580EX II will display the exact picture below as my 600EX II-RT. The 580EX II brought this compatibility and speedlites released from there on support it. For more information you can look up the manual for your camera. Settings displayed will be different depending on the speedlite mounted.
Flash Function Settings screen
07-29-2025 07:32 PM
You are wonderful! Thank you!
