11-07-2016 02:31 PM
I would love to continue to use DPP for its color output. But, where I am struggling with is its slowness to process RAW files. Loading of the RAW files is slow and I cannot tell when my minor corrections are applied to the image (there is no indication of DPP processing my adjustments). The 'Quick Check' of images is good though, without any lag.
Any suggestions?
01-29-2018 02:46 PM
The only time I notice a speed issue is when applying/changing noise reduction and I wonder if a newer/better video card will help?
Choosing edit brings the image and tools up instantly and except for noise reduction all editing changes appear as soon as the new values are chosen. Noise reduction takes up to 8 seconds to finish if both luminance and chrominance settings are adjusted. Batch processing RAW to high quality full size JPG runs 6 to 9 seconds per image.
I have DPP set to use the graphics processor for image processing but I have a feeling the video card I am using is the weak link in the system, it is a Nvidia GTX 570 and I am thinking about upgrading it to something newer and better to see if this gets rid of the noise reduction lagging.
Looking at the system monitor during the time NR is being applied CPU utilization very briefly spikes to 40-44% for less than one second of the noise reduction processing time before dropping to the ~20% level or less for the remainder and back to 0% once the NR process is complete. The GPU appears to be doing nothing staying at 0 to 1% during NR processing. Memory utilization stays around 6%.
I am using RAW files from a 1DX Mark ii and the computer is a HP Z820 with two Xeon 8 core 3.3 ghz. CPUs, the GTX 570 video card, and 128 GB of memory.
Any comments from those using a better video card whether its GPU is being utilized during NR application? However I will definitely wait until the current run on cards (due to the bitcoin mining craze) is over and prices return back to normal.
02-02-2018 12:00 AM
I am having terrible issues where it constantly is crashing. If you apply a saved filter, good luck it will crash. If you go through your photos and come back to it chances are it's locked up. I have a 32 GB system running a 1070 TI 8 GB video card so it's not the hardware, its definitely the software. I thought maybe it was a HDD issue so I put all my images on my SSD... still not the case. These are raw images from a Canon 5D MKIV. Has anyone had any response from Canon? I have ran in admin mode and compability mode for Windows 8, since I'm running Windows 10. I don't have carbonite and also don't have windows media player enabled. My patience is wearing very thin with this software. I am using 4.7.2.1.0
02-02-2018 07:49 AM
I have not had any failures or glitches with 4.7.21. I have been using it extensively in the past week to edit roughly 2,500 images from recent soccer games and it has not had any failures. I have probably spent around 20-30 hours with it because many of these images require a lot of work since they were shot under very bad lighting.
My only complaint with the software is I wish there was a little less delay when applying NR changes and I hope that upgrading to a faster video card will improve that performance.
I am using RAW files from a 1DX M2 and DPP is running on a dual processor HP Z820 with Win 10 professional edition.
02-02-2018 06:00 PM
@LuskPhoto wrote:I am having terrible issues where it constantly is crashing. If you apply a saved filter, good luck it will crash. If you go through your photos and come back to it chances are it's locked up. I have a 32 GB system running a 1070 TI 8 GB video card so it's not the hardware, its definitely the software. I thought maybe it was a HDD issue so I put all my images on my SSD... still not the case. These are raw images from a Canon 5D MKIV. Has anyone had any response from Canon? I have ran in admin mode and compability mode for Windows 8, since I'm running Windows 10. I don't have carbonite and also don't have windows media player enabled. My patience is wearing very thin with this software. I am using 4.7.2.1.0
Did you configure DPP to use the graphics card, and vice versa?
02-02-2018 06:03 PM
02-10-2018 10:19 AM - edited 02-10-2018 10:21 AM
@LuskPhoto wrote:
Yes, tried it both ways.
If you are having stability problems with one piece of software, I would
a) perform a repair install, restart and retest
and/or
b) completely unuinstall the software, restart and install 4.7.2.1 straightaway
I don't think DPP has a repair function, so if you have been upgrading versions on top of one another, try uinistalling, restarting and installing the latest version.
02-10-2018 10:26 AM
@shadowsports wrote:
@LuskPhoto wrote:
Yes, tried it both ways.If you are having stability problems with one piece of software, I would
and/or
I think that's a distinction without a difference. Each new release of DPP appears to be a complete re-installation.
08-11-2018 04:55 AM
I'm using latest version: 4.8.30 which is extremily slow. On two of my computers.
One pretty strong PC with Invidia Geforce GTX1060 (Cannon suggestion - but did not help) and Thinkpad Yoga X3 (also pretty strong). Because it is so slow I can not use DPP for RAW image processing.
3 month ago I got the new 5DmkIV but I see, I was wrong. I should sell all my Canon lences and go for Sony. Also Canonconnect app is a problem. Now I am stackted with a problem and consider do by Adobe software wchich is additiona investmnet.
Was trying to contact Canon support but got stupid aswers. No support, not rational information. Looks like Canon has no many to develop good software. Terrible.
08-11-2018 10:44 AM
@SenJerzy wrote:I'm using latest version: 4.8.30 which is extremily slow. On two of my computers.
You are not having issues with the camera. You’re having issues with your computers. The Thinkpad seems like it could be a notepad, instead of conventional laptop.
Why are you using Canon Connect? Because of the Thinkpad? I would think that you should be using the EOS Utility. I have a 16GB Dell gaming computer and 32GB Dell workstation, both with 4K video cards. DPP runs like a gazelle, even with network files..
08-12-2018 05:04 AM
