DPP not showing folders anymore
jaap
DPP suddenly stopped showing the folder structure (not related to an update), so it's impossible to select any photos. Zoombrowser for instance is still working fine.
I can show (and edit) a photo when I specifically open it withh DPPViewer.exe, but this is just one photo at a time. Bit of a hassle.
Any idea how to correct this?
4 REPLIES 4
The "Folder View" option on the "View" menu turns that on and off.
Bob
I have the same.
It has been working for years (win7, 64bit), but dpp suddenly stopped showing folders. There is no way to open any files. It is not just a setting/option within the application.
Zoombrowser is still working fine (and showing cr2).
So I cannot convert cr2 to jpg.
I've made a complete fresh install of windows and this was one of the first programs to try. It is still not working. Either the original version (cd) or a newer one (canon website).
Dpp opens but doesn't give any messages. Windows events points to an error in flview.dll. If 'fl' stands for folder it might make some sense.
But can anything be done about it?
@marruk wrote:
I have the same.
You're not using Version 4, are you? If you are, then the folder view is controlled by a tiny arrow about halfway down the left side of the DPP window.
Bob
'Unfortunately' that's not it.
Friends and Family
