03-01-2024 02:30 PM
I have talked to Google two different times the last couple of days trying to get the problem resolved that everyone is having with the Canon connect app will not finish setup with the Wi-Fi anymore. After a year of using it it just stopped working
I have spoke to Google and they keep saying it's a manufacturer's problem. When really it's Google's problem
I hope everyone that's having an issue will contact Google until someone finally gets to the right person that can look into this and correct it on our phones
03-01-2024 05:36 PM - edited 03-01-2024 05:37 PM
I'd like to agree with you, but I am not having the issue that many here have posted about.
Formally Pixel4, Pixel6, currently Pixel 8
Former body 6D mkII
Currently Body R5 C
My phones running Canon Connect were / are able to connect to my camera(s) 100% of the time.
I no longer have my 6D2, P4 or P6.
I did report this issue to Canon for investigation. Can you please provide the model of your camera please?
Can you confirm that the behavior is as follows:
Bluetooth connections are successful, but when you try to initiate a Wi-Fi connection to (for example) transfer images the connection fails when you try to enter the password for the camera's Wi-Fi broadcast?
Thanks
03-01-2024 05:42 PM
Yes... That is what is happening
And I did Search - Canon Community
https://community.usa.canon.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=fa...
And there is many people having the same problem with Pixel 6 & 7
03-14-2024 06:13 AM
im having the same issue i think it has to do with an update by pixel but because canon hasnt updated the app since august 23 according to my app store. i think its due to an issue between the wifi on the camera and the phone not wanting to talk properly but its something canon needs to get fixed on their end but probably wont soon if at all.
09-08-2024 11:27 AM
After struggling with the same problem, I have found the phone will connect to the camera quickly as soon as you disable data from your carrier. I believe it is defaulting to looking on the carrier data network for the camera (which it won't find). Disabling data but ensuring the phone is on your local wifi seemed to do the trick. Probably using airplane mode with wifi enabled will also work.
09-08-2024 12:50 PM
Inside the canon app there's a security area in the side bar. Changing from wpa person 2 to 3 was the fix for the issue I was having.
05-25-2025 01:52 PM
I have tried using a Google Pixel 9 Pro and it doesn't connect, but will to a Samsung S21FE and a Samsung S22+, so do you have a contact at Google?
05-25-2025 02:03 PM
Please ensure you're using the current version of the Camera Connect app (https://canon.us/cc) and verify that your camera is registered at https://canon.us/account. As of April 1, 2025, the Camera Connect app requires a Canon Account. If you are not in the United States, please get in touch with Canon in your country or region for help. The Canon Community is hosted and moderated by Canon USA.
08-20-2025 10:17 PM
Are you still having this issue?
