07-27-2024
10:16 AM
10:45 AM
Hello! For some reason canon connect app disconnected my camera from the app and it’s now saying to register it. When I go through the steps it stops at the page where it shows the WiFi (which is correct) and won’t go any further. The only option is to hit the x or go back.
07-27-2024 10:22 AM
07-27-2024 10:26 AM - edited 07-27-2024 10:26 AM
In the CC Application, use the hamburger menu (top right) select Manage Registered Cameras and delete any saved profile for your camera (if present).
Now on your camera's communication menu (you didn't say which body you owned), reset your camera's network setting (just network). Now perform a re-pairing operation.
07-27-2024 10:33 AM
It says to register my camera. No manage camera option. I have a rebel t7 camera
07-27-2024 11:01 AM
(If present). If there are no saved profiles, proceed with repairing after you have reset the network settings on the camera. See page 115
eos-rebelt7-1500d-wfim-en.pdf (c-wss.com)
07-27-2024 11:02 AM
Got it to work. Thanks ALOT
07-27-2024 12:17 PM
Kdgrandstaff,
I had the same or similar problem yesterday trying to connect my camera to using the IOS CameraConnect app. I think the app or my IOS may have been updated and had a similar problem in the past.
Here are the steps (to the best of my recollection):
Good luck!
07-27-2024 02:24 PM
@kdgrandstaff,
Good work. 😃
