07-31-2016 10:08 AM
Ok, I apologize as this is a basic question, but when cropping, I do not need my images to be a particular size, but I do not want any distortion.
I do not think I'm getting any.
Is there anything wrong or different in cropping a image with the lock on and Aspect as an Original?
07-31-2016 10:22 AM
@ilzho wrote:Ok, I apologize as this is a basic question, but when cropping, I do not need my images to be a particular size, but I do not want any distortion.
Changing the aspect ratio when cropping will not distort the photo.
07-31-2016 10:23 AM
Ok, thank you...
07-31-2016 10:27 AM
But, keep in mind there are certain ratios that are more appealing to the eye.
Google 'Golden Ratio' for more information on that.
07-31-2016 10:37 AM
Thanks, I just added 1.618 x 1 in my listing,
I took pictures of a band last night in an outdoor stage so I have lots of pictures to practice on.
07-31-2016 10:43 AM
Food for thought. A 90 minute video from B&H on how to use Lightroom.
https://www.youtube.com/watch?v=IRv5_T0my9k
I gained a better understanding of some of the settings, but more importantly how they interact with one another: i.e. B&W.
07-31-2016 10:52 AM
@ilzho wrote:Thanks, I just added 1.618 x 1 in my listing,
2X3 is usually considerd close enough. But, sure why not.
07-31-2016 10:59 AM
The crop is locked to make you, by default, select from crops that match commonly available print sizes; eg: 4 x 6, 5 x 7, 8 x 10, etc.... You can unlock and make an image that is not one of those sizes but it will not be easy to work with if you want to make a print. It can also be an issue if you want to create a photo calendar, holiday card or a photo album if it has a matte layout that uses standard photo sizes.
07-31-2016 12:28 PM
Thanks I'll watch it.
One question is when exporting photos, the 'Output Sharpening' is unchecked.
If I leave it unchecked, will my sharpening in PP still be exported? or should this be checked?
I'm finding 2 different answers online.
07-31-2016 03:54 PM
@ilzho wrote:Thanks I'll watch it.
The one on export is global sharpening on top of the other sharpening you have applied.
