03-24-2025
09:04 AM
08:58 AM
Will it work? I have an EOS RP, Canon 70-200 2.8 EF lens, which I use a converter to attach to the camera, would a 2x extender work?
I recall reading that the 2x extender didn't work with the EOS RP because the lens needed to extend into the camera's body, and there wasn't enough room with an adaptor, extender, and lens.
03-24-2025 09:23 AM
From the Canon Website
| Lens | 1.4x | 2x | |
| RF 400mm F2.8L IS USM | 560mm | 800mm | |
| RF 600mm F4L IS USM | 840mm | 1200mm | |
| RF 600mm F11 IS STM | 840mm | 1200mm | |
| RF 800mm F5.6L IS USM | 1120mm | 1600mm | |
| RF 800mm F11 IS STM | 1120mm | 1600mm | |
| RF 1200mm F8L IS USM | 1680mm | 2400mm | |
| RF 70-200mm F2.8L IS USM Z | 98mm-280mm | 140mm-400mm | |
| RF 100-300mm F2.8L IS USM | 140mm-420mm | 200mm - 600mm | |
| RF 100-400mm f5.6-8 IS USM | 140mm - 560mm | 200mm - 800mm | |
| RF 100-500mm F4.5 - 7.1L IS USM | 420mm - 700mm | 600mm- 1000mm | |
| (Compatible with 300mm setting or longer only) | |||
| RF 200-800mm F6.3-9 IS USM | 280 - 1120mm | 400 - 1600mm | |
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
03-24-2025 09:31 AM
EF lens mounts on the Canon EF-R lens adapter. Nothing extends into the R camera body. The Canon extender will mount on the lens and then mount on the adapter. The Canon extender has a “nose” that extends into the lens body. That is why the Canon extenders can only be used with canon L lenses. Image quality could take a hit; you can judge that.
03-24-2025 09:41 AM
That's what I read online. Since I'm shooting outside baseball, I'm unsure if that's a big issue, but I'm spoiled with the 2.8 lens.
03-24-2025 09:44 AM
Yes, I'm seeing 2.8L now. I was hoping for solution, but I have not seen one.
03-24-2025 09:49 AM
03-24-2025 09:51 AM
Nope, just read the spec as the name is misleading.
This lens is only compatible with fixed focal length L-series lenses 135mm and over, as well as the EF 70-200/2.8L, EF 70-200/2.8L IS, EF 70-200/4L, and EF 100-400/4.5-5.6L. Additionally, please see the lens and/or camera body manual for full compatibility information with the Extender EF 2X III.
03-24-2025 10:16 AM - edited 03-24-2025 10:16 AM
I have both the EF70-200 f/2.8L II and the EF100-400 f/4.5-5.6L II. Also have the EF 1.4X III and EF 2.0 III. I get better results with the 1.4X and cropping.
03-24-2025 12:26 PM - edited 03-24-2025 12:33 PM
Sorry, loaded the wrong table, here is the EF compatibility
| EF extender compatibility guide | ||||||
| Lens | Lens with 1.4× | AF with 1.4× | IS with 1.4× | Lens with 2× | AF with 2× | IS with 2× |
| 135 mm f/2L USM | 190 mm f/2.8 | Yes | — | 270 mm f/4 | Yes | — |
| 180 mm f/3.5L Macro USM | 252 mm f/5 | Yes | — | 360 mm f/7.1 | No | — |
| 200 mm f/1.8L USM | 280 mm f/2.5 | Yes | — | 400 mm f/3.5 | Yes | — |
| 200 mm f/2.0L IS USM | 280 mm f/2.8 | Yes | Yes | 400 mm f/4 | Yes | Yes |
| 200 mm f/2.8L II USM | 280 mm f/4 | Yes | — | 400 mm f/5.6 | Yes | — |
| 300 mm f/2.8L USM | 420 mm f/4 | Yes | — | 600 mm f/5.6 | Yes | — |
| 300 mm f/2.8L IS USM | 420 mm f/4 | Yes | Yes | 600 mm f/5.6 | Yes | Yes |
| 300 mm f/2.8L II IS USM | 420 mm f/4 | Yes | Yes | 600 mm f/5.6 | Yes | Yes |
| 300 mm f/4L USM | 420 mm f/5.6 | Yes | — | 600 mm f/8 | f/8 only | — |
| 300 mm f/4L IS USM | 420 mm f/5.6 | Yes | Yes | 600 mm f/8 | f/8 only | f/8 only |
| 400 mm f/2.8L USM | 560 mm f/4 | Yes | — | 800 mm f/5.6 | Yes | — |
| 400 mm f/2.8L II USM | 560 mm f/4 | Yes | — | 800 mm f/5.6 | Yes | — |
| 400 mm f/2.8L IS USM | 560 mm f/4 | Yes | Yes | 800 mm f/5.6 | Yes | Yes |
| 400 mm f/4 IS DO USM | 560 mm f/5.6 | Yes | Yes | 800 mm f/8 | f/8 only | f/8 only |
| 400 mm f/5.6L USM | 560 mm f/8 | f/8 only | — | 800 mm f/11 | No | — |
| 500 mm f/4L IS USM | 700 mm f/5.6 | Yes | Yes | 1000 mm f/8 | f/8 only | f/8 only |
| 500 mm f/4.5L USM | 700 mm f/6.3 | f/8 only | — | 1000 mm f/9.0 | No | — |
| 600 mm f/4L USM | 840 mm f/5.6 | Yes | — | 1200 mm f/8 | f/8 only | — |
| 600 mm f/4L IS USM | 840 mm f/5.6 | Yes | Yes | 1200 mm f/8 | f/8 only | f/8 only |
| 800 mm f/5.6L IS USM | 1120 mm f/8 | f/8 only | f/8 only | 1600 mm f/11 | No | f/8 only |
| 1200 mm f/5.6L USM | 1680 mm f/8 | f/8 only | — | 2400 mm f/11 | No | — |
| 70–200 mm f/2.8L IS USM | 98–280 mm f/4 | Yes | Yes | 140–400 mm f/5.6 | Yes | Yes |
| 70–200 mm f/2.8L IS II USM | 98–280 mm f/4 | Yes | Yes | 140–400 mm f/5.6 | Yes | Yes |
| 70–200 mm f/2.8L USM | 98–280 mm f/4 | Yes | — | 140–400 mm f/5.6 | Yes | — |
| 70–200 mm f/4L IS USM | 98–280 mm f/5.6 | Yes | Yes | 140–400 mm f/8 | f/8 only | f/8 only |
| 70–200 mm f/4L USM | 98–280 mm f/5.6 | Yes | — | 140–400 mm f/8 | f/8 only | — |
| 100–400 mm f/4.5–5.6L IS USM | 140–560 mm f/6.3–8 | f/8 only | f/8 only | 200–800 mm f/9–11 | No | f/8 only |
| 100–400 mm f/4.5–5.6L IS II USM | 140–560 mm f/6.3–8 | f/8 only | f/8 only | 200–800 mm f/9–11 | No | f/8 only |
| 200–400 mm f/4L IS USM | 280–560 mm f/5.6 | Yes | [unsure] | 400–800 mm f/8 | f/8 only | [unsure] |
| (without built-in extender 1.4×) | ||||||
| 200–400 mm f/4L IS USM | 400–800 mm f/8 | f/8 only | [unsure] | 560–1120 mm f/11 | No | [unsure] |
| (with built-in extender 1.4×) | ||||||
| TS-E 17 mm f/4L | 24 mm f/5.6 | No | — | 34 mm f/8 | No | — |
| TS-E 24 mm f/3.5L | 35 mm f/5.0 | No | — | 50 mm f/7.1 | No | — |
| TS-E 24 mm f/3.5L II | 35 mm f/5.0 | No | — | 50 mm f/7.1 | No | — |
| TS-E 45 mm f/2.8 | 65 mm f/4.0 | No | — | 90 mm f/5.6 | No | — |
| TS-E 90 mm f/2.8 | 125 mm f/4.0 | No | — | 180 mm f/5.6 | No | — |
https://eflens.com/lens_articles/ef_extender.html
Personal Gallery
