07-22-2023 04:56 PM
I just bought a RF extender 1.4x and 100-500mm lens for my Canon R5. I have owned 2x extenders in the past and never had an issue with mounting it or any lens. Just tried to mount the new extender, didn’t think much about it and just mounted as usual. Turns out it won’t mount properly and I have apparently mounted it backwards on my R5 - stuck and can’t get it off. Now I can’t use the camera or lens. Help!
07-22-2023 08:18 PM
I have this lens and TC with my R5 C. Start with this. The TC can only be fitted on the lens with the zoom adjusted to 300-500mm.
You can't mount it backwards. The flange and mount only goes one way. It works the same way a lens mounts except the lens itself has to be zoomed to 300mm +
07-22-2023 08:18 PM
07-22-2023 08:58 PM
Thank you so much; all problems resolved!
