10-15-2024 02:48 PM
I just got the charger yesterday and it worked just fine the first time I used it tried again today and the light will just stay green like it’s full but the battery is dead and won’t charge
10-15-2024 03:45 PM - edited 10-15-2024 03:47 PM
Hi and welcome!
When you say the battery is dead, do you mean that it has no charge left or that it is no longer showing it is charging? Once the battery is fully charged it has a charge cut-off safety features and will no longer show any activity. Have you put the battery back in the camera to check its status?
10-15-2024 03:48 PM
Is the battery new? Old? I have found that when a battery shows full charge very quickly, then does not work, it is no good.
10-15-2024 06:30 PM
I would say it’s pretty old but it worked one time and then stopped which it was one day apart
10-15-2024 07:24 PM - edited 10-16-2024 01:08 AM
Batteries age and if, as you say, it is old, you should consider a new battery so you can reliably use your camera. They can fail quite quickly.
