EOS Rebel T7 or EOS R - Adaptor for Canon bellows and slide duplicator
Munari
Which adapter do I need to use the bellows and duplicator with EF and RF lens?
12 REPLIES 12
Moderator
Moderator
Hi, Munari!
So that the Community can help you better, we need to know exactly which Canon lens you're using. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
MikeSowsun
Canon only made bellows for FL and FD mount cameras and lenses. There are some 3rd party bellows for EF cameras and lenses.
Which bellows do you have? Which camera, and which lens do you want to use it with?
Mike Sowsun
Munari
Hi.
I have a EOS R and an EOS T7.  I have an EF 50mm macro  and an EF 100mm macro. I have a c Canon Mount adapter EF-EOS R.  I have a vintage Canon Bellows FL and Slide Duplicator.(This came with a %%mm Ring adapter).    I want to connect the Bellows and slide duplicator to  either the T7 or the R.
I very much appreciate your assitance.
Gene Munari
I believe the FL mount bellows is not compatible with EF and RF mount camera bodies.  I recommend that you look for EF mount bellows, which may very likely cost more than either of your cameras.
[EDIT] Another option would a tilt-shift lens for the EF mount.
MikeSowsun
What you are asking for does not exist. No one has made adapters to put EF lenses on an FD mount.
Your best bet is to buy a 3rd party EF bellows that maintains electrical communication.
Mike Sowsun
Thanks for your reply, but let me simplify the question.  I am not trying to use the auto focus function of the lens, I am just trying to connect the camera to the bellows and slide duplicator.  I can do the focus manually and set the aperture and shutter manually as well.   Has to be some adapter or method.
What is the brand and model number of the bellows (in blue)?
JoeySnaps
Enthusiast
I guess you're thinking of achieving something like this, but as has been said, there's no existing adapter to connect FD mount equipment to an EF or RF mount camera.bellows.jpg
There are, however, slide duplicator attachments available on Amazon or Ebay that simply screw into the filter thread of your macro lens. Something like this, for instance.
Would this do the job for you?
R6mkII, various lenses, speedlites. Also legacy Canons going back to T90 and even A1.
This will work.  Does it scan 35mm negative strips as well?  What is the name of the slide duplicator?
Avatar
click here to view the press release
